Drum Head Replacement
Выберете то, что вам нужно
  1. Drum Head Replacement, Drum Head: шаг 1, изображение 1 из 1
    • Loosen the tension rods until all rods are free from the drum.
    • The tension rods are universal for all drums and drum sets.
  2. Drum Head Replacement: шаг 2, изображение 1 из 1
    • Remove the rim and drum head.
    • Keep track of the tension rods by leaving them in their holders on the rim.
  3. Drum Head Replacement: шаг 3, изображение 1 из 1
    • Put on the new drum head first.
    • Put the rim on, making sure that the tension rods are properly aligned.
  4. Drum Head Replacement: шаг 4, изображение 1 из 1
    • Tighten the tension rods with your fingers until you begin to feel tension.
    • You do not want them completely tightened yet. You just want to make sure the head is not wrinkled.
  5. Drum Head Replacement: шаг 5, изображение 1 из 3 Drum Head Replacement: шаг 5, изображение 2 из 3 Drum Head Replacement: шаг 5, изображение 3 из 3
    • Begin to tighten the tension rods in a star pattern using a drum key.
    • Do not tighten the tension rods in a clockwise or counter clockwise pattern.
    • Tighten the rods until you find the sound you want from the drum.
  6. Drum Head Replacement: шаг 6, изображение 1 из 1
    • While tightening the tension rods, tap a drumstick on the drum head about an inch from the tension rods.
    • This is how you will determine which tension rods need to be tightened, loosened, or left alone.
  7. Drum Head Replacement: шаг 7, изображение 1 из 3 Drum Head Replacement: шаг 7, изображение 2 из 3 Drum Head Replacement: шаг 7, изображение 3 из 3
    • Once you have found the sound you like and the drum is in tune, push around the middle of the drum head, moving around the drum.
    • Repeat Steps 6 and 7 until the drum is in tune again.
Заключение
Daniel Barry
Участник с: 11/28/21
145 Репутация
1 руководство автора
Команда
Idaho State University, Team 1-6, Watkins Fall 2021 Участник Idaho State University, Team 1-6, Watkins Fall 2021
ISU-WATKINS-F21S1G6
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 15
За всё время: 200
