Введение
Improper care and attention to a PlayStation 2 controller can wear down buttons and analog sticks. The D-pad is no exception and can become unusable and sticky to the point of repairs being required. Fortunately, D-pads can be easily replaced so you can get back to playing your favorite PlayStation 2 games. To complete this repair, you'll need a Phillips #00 screwdriver, a D-pad replacement, and tweezers.
Once the repair is done, make sure to store and often clean to reduce the chance of needing to replace again.
Выберете то, что вам нужно
Turn the controller over.
Unscrew the six screws using your Phillips #00 screwdriver.
Remove the back cover from the controller.
Slide the triggers off by pulling the trigger off the controller and repeat for another side.
Put the replacement D-pad in the controller.
Put the plastic bracket back on carefully.
Replace the yellow rubber.
Carefully insert the circuit board and reclip the triggers.
Insert the back cover back in place.
Screw the back cover on again clockwise.
Test D-pad to make sure its in working order.
Enjoy your new D-pad.
5 участников успешно повторили данное руководство.
