Введение
Use this guide to replace the internal lithium battery inside PlayStation 3 controllers.
Выберете то, что вам нужно
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
Lift the battery off the motherboard for enough clearance to access the battery connector.
131 участников успешно повторили данное руководство.
14 Comments
Try Amazon Cody
whats is amazon cody?
