DualShock 3 Rear Cover Replacement
Выберете то, что вам нужно
  1. DualShock 3 Rear Cover Replacement, Rear Cover: шаг 1, изображение 1 из 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Rear Cover Replacement: шаг 2, изображение 1 из 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Rear Cover Replacement: шаг 3, изображение 1 из 2 DualShock 3 Rear Cover Replacement: шаг 3, изображение 2 из 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
Заключение
24 участников успешно повторили данное руководство.
3 Комментариев
i have a different dualshock 3 than yours. mine is built in a different way and has a different battery
MasterKlaus Produtions (Swe0b) - Ответить
Sony did that throughout the Dualshock 3’s production as they found out what would cause them to malfunction and fixed the issue. It should be alright as long as you are able to replace the battery when needed.
Aiodensghost -
iran:
نحوهی تعویض طلق دسته پلی سه هم بذارین. لطفان
مجید محمدی - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 18
За последние 30 дней: 73
За всё время: 23,804
