DualShock 3 Trigger Buttons Replacement
Выберете то, что вам нужно
  1. DualShock 3 Trigger Buttons Replacement, Rear Cover: шаг 1, изображение 1 из 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
    I have 2 controllers I'd like to fix, and both have at least one stripped screw in them. Any tips for removing them?
    Joe - Ответить
  2. DualShock 3 Trigger Buttons Replacement: шаг 2, изображение 1 из 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
    Es ist nicht ganz eindeutig das zwischen den beiden Analog-Sticks gedrückt werden muss. Der gelbe Punkt fällt kaum auf. Ein Bild mit Daumen an dieser Stelle wäre gut oder soooo…
    Tom - Ответить
    it’s not very clear but for this step you need to push where the yellow dot is shown on the picture. it’s rather tough. you kind of have to move the whole back plate a bit for it to work.
    Brandon der Blatter - Ответить
    I’m stuck at this step because I can’t for the life of me undo the clip
    IttyBittyGamerVR - Ответить
    Yeah I’m lost here too. I’m pushing where the dot is but nothing is happening. What am I trying to accomplish by pushing there? Is there a clasp on the inside I’m trying to undo or something? I really don’t want to break the controller by using too much force or opening it the wrong way.
    Could it be that the sixaxis I have is constructed differently? Or is this just a difficult step?
    Joe - Ответить
    Adding: I ended up getting the shell off but ended up breaking off a small piece which I'm guessing was securing the front and back shells together. The trigger buttons and pieces remained intact on one of my two controllers which is what I was worried about, though I did have to fit the small trigger pieces back in.
    The one controller seemed to fit back together just fine without the small piece that broke off, and buttons seemed to feel and work fine too.
    Joe -
    I had to use a small flathead to lever it apart.
    mbelanger - Ответить
  3. DualShock 3 Trigger Buttons Replacement: шаг 3, изображение 1 из 2 DualShock 3 Trigger Buttons Replacement: шаг 3, изображение 2 из 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
    the "trigger button guide" link links back to this page :o
    Alexander McMahon - Ответить
    I accidentally popped a trigger off, and both L1 and R1, because I skimmed and didn't read this step. Fortunately it's not hard. The tricky part with the triggers is that there's a little spring on them. You have to press the side of the spring that's pointing away from the trigger against the sloped surface of the controller (look at the other trigger for reference, if you only popped one off). Then you just slide the trigger on until the "handlebar" bits near the center click into place.
    briancaraher - Ответить
    The reset button – a small mostly-rectangular rubberized piece – fell out as I removed the rear cover. It covers the hole near the middle screw and has a post that presses SW1 on the motherboard.
    Fletcher Stern - Ответить
  4. DualShock 3 Trigger Buttons Replacement, Trigger Buttons: шаг 4, изображение 1 из 1
    • While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
  5. DualShock 3 Trigger Buttons Replacement: шаг 5, изображение 1 из 2 DualShock 3 Trigger Buttons Replacement: шаг 5, изображение 2 из 2
    • When reinstalling the #2 trigger, be sure the spring is positioned as shown before popping the axle back into place.
    For this step, i would suggest looking at the other trigger to get an idea of how to put it back in. So if you were replacing the L2 button look at R2 and vice versa.
    Then looking at the picture above, just make sure that the spring is aligned in a similar fashion to the other button. Pushing it forward to match might help as the spring might fall out of place.
    Michael Vichiola - Ответить
    This totally helped me figure this out. Thanks for the excellent tip!
    Steven Folberg - Ответить
  6. DualShock 3 Trigger Buttons Replacement: шаг 6, изображение 1 из 2 DualShock 3 Trigger Buttons Replacement: шаг 6, изображение 2 из 2
    • Pull the black plastic trigger retainer slightly away from the front cover.
    • Pull the #1 button out of the front cover.
  7. DualShock 3 Trigger Buttons Replacement: шаг 7, изображение 1 из 2 DualShock 3 Trigger Buttons Replacement: шаг 7, изображение 2 из 2
    • Before sliding the trigger button retainer back into the rails molded into the front cover, be sure that the cylindrical post attached to the #1 button is sitting flat on the green rubber electronic switch cover. Failure to do so may lead to problems with fit during reassembly, and may cause the controller to not recognize inputs from the #1 button during operation.
    • The trigger button assembly is properly installed when the lip on the trigger button retainer sits flat against the motherboard.
    I really would have liked to see how the little metal piece on the #2 button is supposed to fit back in
    Miko - Ответить
    Wow, so in reverse it’s really really fiddly- probably needs a separate guide as I can’t get it back together with the fiddly trigger parts
    Ben Dawson - Ответить
Заключение
69 участников успешно повторили данное руководство.
8 Комментариев
Might want to add that there's a small catch/tab in the middle of the bottom of the controller that needs to be released when taking apart the covers.
This worked great, and also works on normal Sixaxis controllers. I used this to swap the broken spring from the L2 button on my DS3 for a good spring from my Sixaxis. Works like new now.
Will Foss - Ответить
The little green eletronic ribben where is it supposed to go?
dmall - Ответить
The #00 screwdriver is working better
Leopold287 - Ответить
Did you replace button 2 rod with plastic replacement part or use original rod piece when fixing button 2
Sidney Klemkosky - Ответить
Is there a way I can buy trigger retainers?
CynicalSheep - Ответить
I have SIXAXIS gamepad and I don’t know how to put it back I see it have ribborn.
NiGGaZGamePLay - Ответить
My ps3 original controller's right trigger is not working properly, it won't regester a whole squeeze and also only register's about half way.
Armand Steyn - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 169
За последние 30 дней: 788
За всё время: 113,537
