Выберете то, что вам нужно
Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
Pry the two halves of the shell apart using a plastic opening tool.
Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
Unplug the black and red wires from the power port located on the motherboard.
Remove the old battery from the controller.
Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
Pull out the second ribbon cable to separate the inner workings from the top of the outer shell.
Remove the rubber pads that secure the buttons in place for the arrow buttons, shape buttons, and Playstation Home button.
Remove the old buttons, and replace them with new ones using a pair of tweezers.
41 участников успешно повторили данное руководство.
2 Комментариев
Where can I buy cuh zct2e spares from please
