Введение
Follow this guide to replace the rear panel on a Sony Dualshock 4 CHU-ZCT2U PlayStation controller.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
2 участников успешно повторили данное руководство.
