DualShock 4 CHU-ZCT2U Rear Panel Replacement
Выберете то, что вам нужно
  1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: шаг 1, изображение 1 из 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: шаг 1, изображение 2 из 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: шаг 2, изображение 1 из 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: шаг 2, изображение 2 из 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: шаг 3, изображение 1 из 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: шаг 3, изображение 2 из 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: шаг 3, изображение 3 из 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: шаг 4, изображение 1 из 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: шаг 4, изображение 2 из 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Rear Panel Replacement: шаг 5, изображение 1 из 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement: шаг 5, изображение 2 из 2
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
Заключение
2 участников успешно повторили данное руководство.
Sam Omiotek
Участник с: 02/25/19
65 534 Репутация
Автор 288 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 56
За всё время: 2,117
