Введение
The charging port is a common issue that comes with the Dualshock 4 controller as it could be worn overtime. In this guide, we will go through the steps on how to make a simple and easy repair on the Dualshock 4 CUH-ZCT1's charging port.
Выберете то, что вам нужно
Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
Gently wiggle the charging port's PCB side to side until it detaches from the controller.
7 участников успешно повторили данное руководство.
