Введение
This guide will show the reader how to remove and replace the rumble motors for a Dualshock 4 controller.
Выберете то, что вам нужно
Remove the four 2mm screws on the rear plate using the #000 Phillips screwdriver.
There is a hidden screw underneath the battery pack that attaches the faceplate to the motherboard.
Lift the pack and remove the 10mm screw using the #000 Phillips screwdriver.
With some added pressure, push down and outward in order to free and remove the rumble motors from their socket.
13 участников успешно повторили данное руководство.
