Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
This is how the controller looks like. You will first need to flip it over and unscrew the screws.
Then you will get a plastic open tool to push against the lines to make the controller come apart.
Now with the tool you will make the controller come apart again by pushing against the buttons share and options.
Now you will be taking apart the battery from the controller with tweezers from the little white block.
Now that the battery is gone you will be able to see a little screw and you will need to take it apart.
5 участников успешно повторили данное руководство.
