Введение
CAUTION: AC VOLTAGES. Discharge capacitor before removing, if possible. If not, please leave device unplugged for two to three days before attempting repair. Capacitors can give you a nasty and/or dangerous shock.
Выберете то, что вам нужно
Use a small screwdriver to remove the four screws on the rear corners of the case.
Use your hands to gently pry apart the front and rear halves of the case.
Desolder the defective C5 Capacitor (a black, 680uF 20V radial model).
Replace the resistor with a similar value cap, such as a 25V Rubycon.
Insert the PCB through the front half of the case, making sure that the LED and battery contacts come out fully on the other side of the case (as seen in photo).
Slowly and carefully push the front half of the case down onto the PCB and bottom half of the case.
Verify that the plastic tab inside the front of the case has cleared the metal terminal on the PCB. The front and rear of the case should now join seamlessly together.
Finish the reassembly by tightening all four screws onto the back of the case.
4 участников успешно повторили данное руководство.
