Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If your Dymo LabelManager 160 is not properly printing from Dymo D1 Label Cassettes, the wheelhead which unspools the cassettes may be not functioning. This guide leads you through the process of opening up the LabelManager and changing the wheelhead. Keep in mind that the device has loose parts.
Запчасти
Детали не указаны.
  1. Place the device face-down to access the battery compartment.
    • Place the device face-down to access the battery compartment.
  2. Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
    • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
  3. To open the cartridge compartment, simply lift on the front of the device.
    • To open the cartridge compartment, simply lift on the front of the device.
  4. Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment. Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
    • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
  5. Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
    • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
  6. Gently remove the rubber keyboard from the device. Gently remove the rubber keyboard from the device. Gently remove the rubber keyboard from the device.
    • Gently remove the rubber keyboard from the device.
  7. Using a Phillips #0 screwdriver, remove the three 1.1 mm screws from the circuit board.
    • Using a Phillips #0 screwdriver, remove the three 1.1 mm screws from the circuit board.
  8. Lifting the circuit board, use a Phillips #1 screwdriver to remove the two 1.2mm screws from under the circuit board.
    • Lifting the circuit board, use a Phillips #1 screwdriver to remove the two 1.2mm screws from under the circuit board.
    hoe verwijder je de display
    aslan - Ответить
  9. Proceed to lift the excess device components until the rollerblade is visible. Proceed to lift the excess device components until the rollerblade is visible.
    • Proceed to lift the excess device components until the rollerblade is visible.
  10. With the device components exposed, gently lift the wheelhead out of the label maker.
    • With the device components exposed, gently lift the wheelhead out of the label maker.
Заключение
Еще один человек закончил это руководство.
Matthew Jenkins
Участник с: 27.01.2016
229 Репутация
Автор 2 руководств
Команда
University of Alabama, Team 1-4, Sydow campbell Spring 2016 Участник University of Alabama, Team 1-4, Sydow campbell Spring 2016
UA-SYDOW CAMPBELL-S16S1G4
4 членов
Автор 4 руководств
Комментариев: 2
Group 9: Over all looks great. Pictures are great quality and hand placement in pictures. The circles and arrows should all be red. The only time the color changes is if there are different steps within a single picture.
Zachary Parker - Ответить
thank you for the procedure, i mis one screen in the procedure how to detach display?
aslan - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 15
За последние 30 дней: 52
За всё время: 1,196
