Введение
This guide is suppose to help you open up the device. Do not do this unless certain that you need to check something.
Выберете то, что вам нужно
Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
