Введение
The discdrive is found next to the motherboard and power board inside the device. This guide will take you through the steps of removing the discdrive for replacement.
Выберете то, что вам нужно
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
Use a Phillips #1 screwdriver to remove the two screws that secure the Optical Drive.
Lift the disc drive up to a 45 degree angle and pull back out of the device shell
2 участников успешно повторили данное руководство.
