Dynex DX-WBRDVD1 Power Supply Board Replacement
Выберете то, что вам нужно
  1. Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: шаг 1, изображение 1 из 2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Top Cover: шаг 1, изображение 2 из 2
    • Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
  2. Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 2, изображение 1 из 1
    • Remove the two 5mm screws on the left and right side panels.
    • There is one screw on each side that secures the cover to the body of the device.
  3. Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 3, изображение 1 из 1
    • Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
    • Check that the power cord is not preventing the device from opening or closing.
  4. Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: шаг 4, изображение 1 из 2 Dynex DX-WBRDVD1 Power Supply Board Replacement, Power Supply Board: шаг 4, изображение 2 из 2
    • Remove the 9-pin white wire from the power board (brown) that connects to the motherboard (green).
  5. Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 5, изображение 1 из 2 Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 5, изображение 2 из 2
    • Remove the front plate of the device by removing the top two screws on either side and pulling the plate away.
    • Make sure to place the grounding wire between the screw and the device when reassembling.
  6. Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 6, изображение 1 из 2 Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 6, изображение 2 из 2
    • Remove the 4 screws holding the power board to the body of the device.
    • Remember to connect a grounding wire to the screw next to the front panel and optical drive when reassembling.
  7. Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 7, изображение 1 из 2 Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 7, изображение 2 из 2
    • Press down on the plastic flap to unlatch the white clip on the edge of the power supply board.
  8. Dynex DX-WBRDVD1 Power Supply Board Replacement: шаг 8, изображение 1 из 1
    • Remove the power supply board.
Заключение
3 участников успешно повторили данное руководство.
Caleigh Firth
Участник с: 04/05/18
438 Репутация
Автор 3 руководств
Команда
Linn Benton Community College, Team S1-G2, Johnson Spring 2018 Участник Linn Benton Community College, Team S1-G2, Johnson Spring 2018
LBCC-JOHNSON-S18S1G2
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 7
За последние 30 дней: 16
За всё время: 706
