Введение
This guide was made to help people replace a power supply board in a Dynex DX-WBRDVD1 DVD player. The power supply board regulates and supplies power to the connected components in the DVD player that make it operational. Without the DVD power supply board, the DVD player will be unable to operate.
Before starting, make sure to turn off and unplug the DVD player from any external power source.
Выберете то, что вам нужно
Remove the four 5mm Phillips #1 screws that connect the black outer shell to the silver back of the device.
Lift the black cover to a 45 degree angle from the rear of the device and pull the cover away entirely.
Remove the 9-pin white wire from the power board (brown) that connects to the motherboard (green).
Remove the front plate of the device by removing the top two screws on either side and pulling the plate away.
Press down on the plastic flap to unlatch the white clip on the edge of the power supply board.
3 участников успешно повторили данное руководство.
