Введение
In this guide you will be able to remove the cover on the power cord and remove and reattach the power cord for the Dyson Ball Animal.
Выберете то, что вам нужно
Turn off and unplug the vacuum.
Remove the vacuum canister from the front of the vacuum.
Flip the vacuum around and remove the hose so it is not blocking the back of the vacuum.
After all the screws are released there are two tabs that must be pressed in and towards the center.
Follow the black cord from the power cord.
Pinch the plastic piece.
Remove from the metal tongue.
There is also a black case that needs to be opened in order to remove the power cord.
After opening the case pull apart the wire and attach the new wire.
3 участников успешно повторили данное руководство.
3 Комментариев
Great tutorial! The pictures were awesome, I replaced my cord in about 15 minutes thanks to this post. The only thing you might want to add is the gray switch with the spring. Mine fell out while I was trying to put the unit back together and I had to research how it went back together correctly. Thanks again!
Jim
I had the same spring lever issue. This video shows how to replace them.
Thank you for the YouTube link on the button reassembly. I should have expected it to be sitting loaded when I disassembled it.
