Введение
If you are using your Dyson Multi Floor Upright and there are problems or damages to the electrical cord that are causing issues with the power of your vacuum, the problem is most likely the electrical cord. The best solution to this problem is to replace the electrical cord.
Выберете то, что вам нужно
Press the red button on the back to release the hose and allow for easy access to the back
Remove the four 15 mm T-10 black screws now showing in the back of the vacuum hose track, using the Phillips 0 screwdriver found in the iFixit tool kit.
Use a pair of needle nosed pliers to press both tabs simultaneously.
Remove the hatch carefully exposing the wiring underneath
Pull vertically on the grey cord now and it should separate from the rest of the vacuum
Еще один человек закончил это руководство.
Один комментарий
Supposing that one doesn't hold onto the front part, and the spring and lever fall out, how does one replace said spring and lever?
