Введение
This guide will show you how to replace the gasket at the top of the cyclone block of a Dyson DC37 Allergy.
It should apply to the entire DC37 range and is probably valid for Dysons of similar architecture (such as the DC 33).
This guide will show you how to easily disassemble and reassemble the cyclone block. Have a cloth handy in addition to the torx screwdriver to clean these hard-to-reach parts
Выберете то, что вам нужно
Remove the Cyclone block from the rest of the vacuum cleaner (grey button on the main body)
Position the tank above a trash can or bag (open) then press the red button to release the bottom of the tank and empty the contents
Also remember to remove the fine dust filter which is simply inserted in the center of the cyclone block. It can be cleaned under the tap (see care instructions).
Next you will separate the cyclone block from the dust tank
Press the grey button to detach the transparent tank from the colored cyclone block.
Wipe off the outside of the cyclone block before tackling it
Remove the 7 (seven) T8 Torx screws that attach the lower skirt to the upper body using a Torx screwdriver
Remove the gasket attached to the lower part of the body, clean it and set it aside
The lower part can be cleaned with a cloth and/or water. It is possible to remove the skirt using a thin tool to release the retaining notches, but it is not necessary for this repair.
The body is now clearly visible. Get a new rag before continuing
You will now remove the cradle that houses the dust filter. This one is simply nested in the top block
Once this operation is done, simply remove the cone by pulling it to extract it from the socket
You can clean the cone as well as the inside of the top of the cyclone block
Unscrew the last 7 screws using the Torx screwdriver
Once the screws are removed, you can easily separate the cap from the intermediate block
A little cleaning is necessary
The cover is separated into 4 parts: the lid, 2 white pieces, one with moveable guides and the seal
It is possible to make a temporary repair with adhesive tape to seal and reconnect the pieces
You can see my temporary repair here while I wait for the replacement part to arrive
To reassemble your device, follow the instructions in reverse order.
2 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
5 Комментариев
Salut, qu'entendez-vous par joint, pouvez-vous expliquer un aliotle plus pour que je puisse vous aider, merci :-)
Je n'ai pas de référence Dyson. La pièce d'origine est introuvable. Mais il s'agit juste d'une feuille de mousse de caoutchouc coupée à la bonne forme, il y a de nombreux vendeurs de pièces compatibles. Une recherche de 'joint cyclone DC37', ou 'joint d'étanchéité DC37' remontent des vendeurs. On peut aussi chercher en anglais: 'DC37 Gasket' ou 'DC37 Cyclon Gasket' devrait donner de bon résultat.
Bonjour,
Pouvez vous donner la taille du tournevis Torx nécessaire, SVP ?
Merci par avance
Il s'agit d'un T8 (il est indiqué dans l'en tête). La taille est normalement indiquée sur le tournevis, ou la tête dans le cas de tête interchangeable.
