Введение
This guide will take you through the removal of the of the sole plate and the air muscle assembly. The final goal of this guide is to remove and replace the air muscle assembly.
Выберете то, что вам нужно
Remove the dust collector using the red button located at the top of the bin
Go to the wheel on the right side of the vacuum.
Remove the cap of wheel by sliding in a small metal spudger or flat head screwdriver and gently prying up.
Инструмент, используемый на этом этапе:Metal Spudger$2.99
Use the pointed end of a metal spudger to pull off the e-clip.
Инструмент, используемый на этом этапе:Flush Cutter$29.99
Use the wire cutters to cut the zip tie holding the tube on.
Use a flat head screwdriver or metal spudger to push the plastic out of the way and remove the air muscle.
4 участников успешно повторили данное руководство.
