Dyson DC39 Origin Ball Wheels Replacement
Выберете то, что вам нужно
  1. Dyson DC39 Origin Ball Wheels Replacement, Bin: шаг 1, изображение 1 из 3 Dyson DC39 Origin Ball Wheels Replacement, Bin: шаг 1, изображение 2 из 3 Dyson DC39 Origin Ball Wheels Replacement, Bin: шаг 1, изображение 3 из 3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: шаг 2, изображение 1 из 3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: шаг 2, изображение 2 из 3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: шаг 2, изображение 3 из 3
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin Ball Wheels Replacement: шаг 3, изображение 1 из 3 Dyson DC39 Origin Ball Wheels Replacement: шаг 3, изображение 2 из 3 Dyson DC39 Origin Ball Wheels Replacement: шаг 3, изображение 3 из 3
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
  4. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: шаг 4, изображение 1 из 2 Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: шаг 4, изображение 2 из 2
    • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
    • There is one screw located at the center of each wheel.
  5. Dyson DC39 Origin Ball Wheels Replacement: шаг 5, изображение 1 из 3 Dyson DC39 Origin Ball Wheels Replacement: шаг 5, изображение 2 из 3 Dyson DC39 Origin Ball Wheels Replacement: шаг 5, изображение 3 из 3
    • Pull the wheel away from the main body of the device.
    • This may require a lot of force. The plastic wheel may bend slightly.
Заключение
Michael Hutcheson
Участник с: 04/26/17
297 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S23-G6, Livingston Spring 2017 Участник Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 2,122
