Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble
Выберете то, что вам нужно
  1. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the chassis: шаг 1, изображение 1 из 1
    • Turn the unit over and remove the 4 Torx T15, 18mm pan head screws.
  2. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the wheels: шаг 2, изображение 1 из 1
    • Remove the T15 21mm countersunk head screw and pull the wheel off (on each side)
  3. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws in the case: шаг 3, изображение 1 из 2 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws in the case: шаг 3, изображение 2 из 2
    • Remove the 8 Torx T15, 22mm pan head screws from the bottom…
    • and the 2 22mm Torx T15 screws from the top.
  4. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws on the upper air pipe: шаг 4, изображение 1 из 3 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws on the upper air pipe: шаг 4, изображение 2 из 3 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the screws on the upper air pipe: шаг 4, изображение 3 из 3
    • Press the button to release the dust container.
    • Carefully press the locking lugs inwards with a screwdriver or by hand until the upper part with the suction tube can be folded further upwards.
    • Then another 2 Torx T15, 18 mm cylinder head screws become visible, which are removed (they fasten the cable drum on the inside).
  5. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loosen the intake manifold holder screw: шаг 5, изображение 1 из 1
    • Loosen the one PH2 screw of the intake manifold holder (it fastens the cable drum on the inside).
  6. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the lower case: шаг 6, изображение 1 из 1
    • Carefully pull the case halves apart. You now have the HEPA filter and the cable drum in the upper half and the motor in the motor capsule in the lower half.
  7. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove the upper case: шаг 7, изображение 1 из 1
    • The upper part is clipped into the housing with 2 locking notches. Try to unhook with a screwdriver and some hand wiggling. Don't grab the HEPA filter too tightly as it is made of paper and is easily dented.
  8. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loose the cable from the motor: шаг 8, изображение 1 из 3 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loose the cable from the motor: шаг 8, изображение 2 из 3 Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Loose the cable from the motor: шаг 8, изображение 3 из 3
    • The switch is on the cable drum. The cable is connected to a blade connector which is secured by a fine tab to prevent vibration from loosening it. If you press on the lug with a fine screwdriver, the connection can be released without too much force. Disconnect the black cable.
    • Next to it is a long, black box in which the white cable is plugged. Press the lug with the screwdriver here as well and loosen the plug connection.
    • Then carefully pull both cables out of the strain relief on the housing.
    • Now you have mechanically and electrically separated the motor from the cable drum.
  9. Dyson DC52 / DC54/ DC47/ DC 48/ DC 78 Disassemble, Remove HEPA filter: шаг 9, изображение 1 из 1
    • To separate the cable reel and the HEPA filter, hold the HEPA filter carefully and turn the cable reel approx. 90° clockwise. Then both parts can be separated.
    • Done. You have separated the essential main parts.
    • The cable reel, the HEPA filter and the motor can be easily obtained as spare parts on the Internet. The filter is available for around 60 euros, the motor and cable drum for around 80 euros.
    • During reassembly it can easily happen that the cable drum is stressed. In this case the vacuum works well but the cable will not automatically rewind if you press the button.
    • Therefore you have to assure that the white notches (see step 7) fit in the corresponding openings and not being pushed deeper.
    • Thighten the 2 Torx screws from step 4 and the PH2 screw from step 5 only very little. Always test the rewinding function of the cable. Only at the end if the rewinding works well, tighten these screws and close the lid with the suction tube.
Финишная черта
6 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
HowThingsWork
Участник с: 07/21/21
2 240 Репутация
Автор 11 руководств
2 Комментариев
In the BitLife Life Simulator, you will play a simulation game where you must make life-changing choices. For instance, you could wed the love of your life, start a family, and further your education. You can also choose things that, to be honest, will frighten your parents, but hey, maybe they'll be entertaining? You can start dating, start looking for adventure, incite a prison riot, smuggle bags of drugs, or cheat on your significant other. You choose the narrative. Although there are many interactive story games available, this is the first text-based life simulator that can adequately recreate the story.
Chan Mina - Ответить
Thank you, it worked as described. The hardest part is step 7, as the white lugs are solidly part of the body and have no "give". Undoing them requires prising between the lug and the shell forcefully with a fine screwdriver to spring the shell locating tag off. There is then a lug down by the cable entry which is easily sprung with a fine screwdriver. For reassembly I was able to use fine snipe-nose pliers to grasp a piece of the white body through the opening on the switch side and pull the lug into position. The other lug was harder but I made a small hole in the lug with a small screwdriver and used it to drag the lug into position.
Chris P - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 66
За последние 30 дней: 280
За всё время: 7,782
