Введение
The battery is what makes this vacuum handheld and portable. It can keep the vacuum operational for approximately 3.5 hours.
Выберете то, что вам нужно
Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
Pull the battery pack down and away from the main body and remove it from the device.
6 участников успешно повторили данное руководство.
9 Комментариев
Works for the DC44 animal also. :)
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
