Dyson DC58 Cyclone Replacement
Выберете то, что вам нужно
  1. Dyson DC58 Cyclone Replacement, Bin: шаг 1, изображение 1 из 1
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
  2. Dyson DC58 Cyclone Replacement: шаг 2, изображение 1 из 1
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
  3. Dyson DC58 Cyclone Replacement: шаг 3, изображение 1 из 1
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
  4. Dyson DC58 Cyclone Replacement: шаг 4, изображение 1 из 2 Dyson DC58 Cyclone Replacement: шаг 4, изображение 2 из 2
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
  5. Dyson DC58 Cyclone Replacement, Main Body: шаг 5, изображение 1 из 1
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
  6. Dyson DC58 Cyclone Replacement: шаг 6, изображение 1 из 2 Dyson DC58 Cyclone Replacement: шаг 6, изображение 2 из 2
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
  7. Dyson DC58 Cyclone Replacement: шаг 7, изображение 1 из 1
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
  8. Dyson DC58 Cyclone Replacement, Cyclone: шаг 8, изображение 1 из 2 Dyson DC58 Cyclone Replacement, Cyclone: шаг 8, изображение 2 из 2
    • Use the metal spudger placed between the black rim and the purple rim to separate the purple screen cover from the cyclone body.
    • Pry all the way around the screen cover.
  9. Dyson DC58 Cyclone Replacement: шаг 9, изображение 1 из 1
    • Use a T9 screw driver to remove the five 14mm screws around the edge of the cyclone body.
  10. Dyson DC58 Cyclone Replacement: шаг 10, изображение 1 из 2 Dyson DC58 Cyclone Replacement: шаг 10, изображение 2 из 2
    • Pull down on the black tube-like part of the silver cyclone body to remove it from the cyclone of the Dyson.
    • You may need to wiggle the tube as you are pulling down to loosen the pieces apart.
Заключение
19 участников успешно повторили данное руководство.
Herllaine Asistio
Участник с: 09/17/15
221 Репутация
1 руководство автора
Команда
CSU Fullerton, Team 2-4, Bruce Fall 2015 Участник CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 членов
Автор 19 руководств
11 Комментариев
Great job, very useful thanks
Don - Ответить
Fantastic thanks!!!!
robh - Ответить
Very helpful indeed.
macx - Ответить
Thanks. Had to wash out the dog smell. This did the trick.
David Parsons - Ответить
Thanks. Had to wash out the dog smell. This did the trick when new filters wouldn't. Shame on Dyson for not making an easier to clean vacuum.
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 31
За последние 30 дней: 137
За всё время: 23,614
