Введение
This Guide is to help you if you need to get access to the inside of your fan to fix wire the motor or other parts. We will walk you through the steps to safely open it up and put it back together.
Выберете то, что вам нужно
With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
Using a Torx T20 Screwdriver, remove the screw in the center of the base.
Remove the two screws connected to the rotation arm.
Почти готово!
Финишная черта
