Dyson V10 Motorhead Disassembly
Выберете то, что вам нужно
  1. Dyson V10 Motorhead Disassembly, Before and after cleaning.: шаг 1, изображение 1 из 2 Dyson V10 Motorhead Disassembly, Before and after cleaning.: шаг 1, изображение 2 из 2
    • Translucent cover before and after cleaning.
  2. Dyson V10 Motorhead Disassembly, Removing rotating brush and red lid.: шаг 2, изображение 1 из 3 Dyson V10 Motorhead Disassembly, Removing rotating brush and red lid.: шаг 2, изображение 2 из 3 Dyson V10 Motorhead Disassembly, Removing rotating brush and red lid.: шаг 2, изображение 3 из 3
    • Remove red lid by releasing the clamps (yellow arrows) with a spudger to get access to more screws, that hold the translucent shield.
    • Remove Two Torx screws that hold the silver cover-plate on the opposite side of the motorhead that covers the translucent shield.
    • Remove the rotating brush by realeasing it with a coin.
  3. Dyson V10 Motorhead Disassembly, Removing screws, that hold the silver and the translucent shield.: шаг 3, изображение 1 из 1
    • Remove the five Torx screws (red), that hold the translucent shield.
    • Remove the single shorter Torx screw (yellow), that fixes the silver and the translucent shield.
  4. Dyson V10 Motorhead Disassembly, Removing the silver shield.: шаг 4, изображение 1 из 1
    • Remove the silver shield by gently pulling into the directions of the red arrows. (This is the only tricky part of the whole procedure.)
  5. Dyson V10 Motorhead Disassembly, Removing the translucent shield.: шаг 5, изображение 1 из 2 Dyson V10 Motorhead Disassembly, Removing the translucent shield.: шаг 5, изображение 2 из 2
    • After removal of the silver-shield the translucent shield can be removed easily. The black and white cables are attached with the black plug and can be reattached easily on reassambly.
  6. Dyson V10 Motorhead Disassembly, Ready for spring-cleaning.: шаг 6, изображение 1 из 1
    • After removal of the translucent shield, both the shield and the silver-skeleton that holds the rotating motorhead can be cleaned thoroughly.
Заключение
Robert Hoppe
Участник с: 09/23/17
175 Репутация
1 руководство автора
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 43
За последние 30 дней: 216
За всё время: 651
