Выберете то, что вам нужно
Remove the first flap using a flathead screwdriver or small coin to turn the mechanism to the unlocked position.
Use a T10 Torx screwdriver to remove all visible screws. Remove the secondary plate and any further screws. Note the location of the one long screw, the rest are interchangeable at this stage.
You now have access to the motor assembly. This can be removed from the body of the brush bar with some gentle twisting and tugging.
Once removed, you can use a 9mm socket to rotate a spiral mechanism and loosen the belt drive.
If you need to remove the belt drive system, start by using a small thin tool such as a metal skewer to lift it off the small pulley.
Use the flat spot on the large pulley to lift the belt out of the pulley. use the same mechanism to reverse.
Use a T8 Torx screwdriver to remove the screw holding the spiral drive mechanism in place. This is the drive mechanism that spins the brush bar.
Use a thin flat device such as a spudger, screwdriver, or metal prying tool to lift the spiral drive piece off its axle.
You can now see one side of the ball bearing. This is where hair gets trapped if the brush bar is not cleaned regularly enough.
You can remove the hair and regrease the ball bearing from here.
5 участников успешно повторили данное руководство.
Один комментарий
It was the final torx in the spiral drive that I hadn't noticed to get t it apart, thank you 👍
