Dyson V6 Motorhead Brush Bar Replacement
Выберете то, что вам нужно
  1. Dyson V6 Motorhead Brush Bar Replacement, Brush Bar: шаг 1, изображение 1 из 1
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. Dyson V6 Motorhead Brush Bar Replacement: шаг 2, изображение 1 из 1
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  3. Dyson V6 Motorhead Brush Bar Replacement: шаг 3, изображение 1 из 3 Dyson V6 Motorhead Brush Bar Replacement: шаг 3, изображение 2 из 3 Dyson V6 Motorhead Brush Bar Replacement: шаг 3, изображение 3 из 3
    • Pull the brush bar out of the housing.
Заключение
3 участников успешно повторили данное руководство.
Addie Hedge
Участник с: 01/24/17
710 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 22-6, Maness Winter 2017 Участник Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 членов
Автор 5 руководств
4 Комментариев
Not so fast, there are teeth on the lower roll insert that can interfere with teeth on the housing. Is there a purpose for these teeth, maybe manufacturing mold release? My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4 or 5 revolutions, then shuts off power for a second, then comes back on without the roller spinning at all. I can see it is the teeth interlocking but don’t know how it makes the first 4 or 5 revs. Very strange indeed!!
dooleyew - Ответить
I have the same problem, where the teeth seem to be engaging and stopping the revolutions. Any fix for this?
Dave Duddleston - Ответить
I have the same problem and I never signed up for the warranty.
Donna Sweeney - Ответить
My motorhead works intermittely. I took it apart and cleaned everything to no avail. The guy at Starks vacuum in Sherwood OR said it was plugged and he would take it apart and clean it for $100. Hmmmm, what can he clean that I can’t?
Roger and Karen Risch - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 32
За всё время: 21,783
