Введение
Brushbar replacement, the brushbar may need frequent cleaning removing hair or other debris wrapped around the brush. After long use the bar may need replacement.
Запчасти
No parts specified.
  1. Press the button to disconnect the vacuum head from the connecting pole.
    • Press the button to disconnect the vacuum head from the connecting pole.
  2. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  3. Turn the end cap counterclockwise using the iFixit Opening Tool.
    • Turn the end cap counterclockwise using the iFixit Opening Tool.
    • If you do not have an iFixit Opening Tool, a quarter may be used instead.
  4. Pull the brush bar out of the housing. Pull the brush bar out of the housing. Pull the brush bar out of the housing.
    • Pull the brush bar out of the housing.
Заключение
Addie Hedge
Участник с: 24.01.2017
573 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 22-6, Maness Winter 2017 Member of Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 членов
Автор 5 руководств
Комментариев: 2
Not so fast, there are teeth on the lower roll insert that can interfere with teeth on the housing. Is there a purpose for these teeth, maybe manufacturing mold release? My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4 or 5 revolutions, then shuts off power for a second, then comes back on without the roller spinning at all. I can see it is the teeth interlocking but don’t know how it makes the first 4 or 5 revs. Very strange indeed!!
dooleyew - Ответить
I have the same problem, where the teeth seem to be engaging and stopping the revolutions. Any fix for this?
Dave Duddleston - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 8
За 7 дней: 77
За 30 дней: 351
За всё время: 12,354
