Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Collection Bin removal, requires battery removal before starting.
  1. Depress the button releasing an end of the connection tubing. Pull the connection tubing away from the bottom vacuum head. Pull the connection tubing away from the bottom vacuum head.
    • Depress the button releasing an end of the connection tubing.
    • Pull the connection tubing away from the bottom vacuum head.
  2. Depress the last button, freeing the connection tubing. Pull connection tubing away from the upper vacuum head. Pull connection tubing away from the upper vacuum head.
    • Depress the last button, freeing the connection tubing.
    • Pull connection tubing away from the upper vacuum head.
  3. Pull down on the red release tab. When the tab is fully engaged, the bottom of the bin should open.
    • Pull down on the red release tab.
    • When the tab is fully engaged, the bottom of the bin should open.
  4. Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head. Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
    • Pull down on the release tab a second time, this time the collection bin should release from the upper vacuum head.
  5. Pull the collection bin away from the upper vacuum head. Pull the collection bin away from the upper vacuum head. Pull the collection bin away from the upper vacuum head.
    • Pull the collection bin away from the upper vacuum head.
Заключение
Addie Hedge
Участник с: 24.01.2017
594 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 22-6, Maness Winter 2017 Участник Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 54
За всё время: 2,108
