Введение
In case the device is not turning on and the battery has been completely charged for 5 hours, the battery may need to be replaced. The battery can be easily removed and replaced.
Выберете то, что вам нужно
Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
Turn device completely over to view battery pack.
Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
59 человек успешно провели ремонт по этому руководству.
16 Комментарии к руководству
I have replaced the battery and I still got a flashing red light, any ideas
I replaced my battery and charged the new one- my vac doesnt work
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
