Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the motor or cyclone of the Dyson v6 Absolute is not functioning properly, the main body of the device can be removed.
Выберете то, что вам нужно
Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
Push the red lever down a second time to release the debris bin.
Use tweezers to pinch the white clips together.
Widely hold the tweezers apart to get them to reach between the two white clips.
Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
Tilt and pull the main body away from the cyclone.
There may be a loud snap when the main body separates from the cyclone.
12 участников успешно повторили данное руководство.
Один комментарий
The motorhead does not rotate or only works irregularly?
There are two little metal tabs sitting above the lever of the bin and are meant to make electrical contact to the wires running around the bin and down the wand to the motorhead to power the rotating brush. Those metal-tabs tend to get bend and/or their ends might have become dislocated out of their brackets.
Thanks for Your guide!!! It helped me to remove the Main Body from the Cyclone properly and get those metal-tabs back in place.
