Введение
Follow this guide to replace the head assembly on a EDCO Disk Grinder model 50200-HD.
This repair requires two people.
Выберете то, что вам нужно
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a 9/16 inch socket to remove the two bolts securing the weighted hood.
Use a 9/16 inch socket to loosen the bolts securing the motor mount.
Slide the motor towards the front of the machine as far as it will go to loosen the belt tension.
Use a 9/16 inch socket to tighten the four bolts back down to lock the motor in a position where there's the least belt tension.
Pinch a flathead screwdriver between the belt and sheave.
Rotate the sheave and pivot the belt up and away from its groove.
Continue to rotate the sheave with once hand while holding the flathead screwdriver with the other to fully dislodge the belt from the groove.
Use a 5/32 inch hex wrench to loosen the set screw securing the sheave to the head assembly shaft.
Use a 5/32 inch hex bit with an extension to loosen the two set screws securing the head assembly shaft to the upper bearing.
Use a 5/32 inch hex bit with an extension to loosen the two set screws securing the head assembly shaft to the lower bearing.
Use a 7/32 inch hex key to remove the four flat screws securing the disk to the head assembly.
Use a dead blow hammer to hit the head assembly shaft straight down until it is flush with the upper bearing bracket, or as far as it will go.
Use an appropriately-sized punch to knock the head assembly the rest of the way out.
Insert the new head assembly up into the bearing as far as you can by hand.
Use a dead blow hammer to knock the head assembly up into the machine until there is no play in the shaft spacer.
5 участников успешно повторили данное руководство.
