Введение
Follow this guide to replace the power cord on a EDCO Disk Grinder model 50200-HD.
Выберете то, что вам нужно
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a Phillips screwdriver to remove the screw securing the red on/off lever.
Use a Phillips screwdriver to remove the two screws securing the yellow switch guide to the switch assembly.
Remove the yellow switch guide from the switch assembly.
Remove the black plastic spacer from underneath the yellow switch guide.
Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
Use a 3/8 inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
Use a 11/32 inch socket to remove the four nuts from the on/off switch bracket.
Use a flathead screwdriver to remove the screw securing the two green ground wires to the switch housing.
Separate the green wires from each other and move them away from the switch housing.
Use a flathead screwdriver to loosen the two screws securing the black and white wires running from the power cord to the switch.
Use a 1-1/16 inch wrench or an adjustable wrench to loosen the power cord's strain relief fitting from the switch housing.
Once the fitting is loose enough to turn by hand, twist the power cord and fitting counterclockwise until it is fully unthreaded from the switch housing.
Use two adjustable wrenches to unscrew the strain relief fitting by turning the locknut counterclockwise relative to the strain relief fitting.
1-1/16 inch lock nut
15/16 inch strain relief fitting
Insert a flathead screwdriver into the fitting and push the blue grommet out to remove it from the housing.
Еще один человек закончил это руководство.
