Введение
This guide will teach you how to replace the backplate of the EasySMX ESM-9110 controller.
Выберете то, что вам нужно
Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
Insert a plastic opening tool into the slit on the side of controller.
Wiggle the tool until the cover becomes loose.
Repeat this on the other side of Controller.
Use a Phillips #000 screwdriver to remove four 20 mm screws from the controller's faceplate.
Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
Remove the faceplate of the controller by lifting it directly up from the backplate.
Use a Phillips #000 screwdriver to remove the two 10 mm screws from the daughterboard off the backplate.
Remove the daughterboard once screws are off.
Еще один человек закончил это руководство.
