Введение
Over time, the buttons on your EasySMX X15 controller may become less responsive or get stuck. Replacing the buttons is a relatively simple process that you can do at home with a few basic tools. This guide will walk you through how to replace the buttons.
Note: You don't need to remove the battery as shown in Step 3. However, it is important to disconnect the battery from the board before you move on.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the four 9 mm screws from the bottom of the EasySMX X15.
Use an opening tool to gently pry between the seams of the controller to separate the lower and upper casings.
Push on alternating sides of the connector to disconnect the red battery cable from the board.
Disconnect the vibration motor cables from the connectors on the circuit board.
Use a Phillips #00 screwdriver to remove six, 6mm screws from the board.
Gently lift the board away from the upper casing, maneuvering it around the triggers by lifting it from the bottom, away from the upper casing.
To reassemble your device, follow these instructions in reverse order
