Введение
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Use this spark plug in your Echo Chain Saw CS-4910 (2020).
Make sure you have the ignition switch turned off before starting your repair.
Use your fingers to loosen the air filter cover knob.
Use your fingers to pull up and disconnect the spark plug boot.
Почти готово!
Заключение
