Введение
In this tutorial, I'll show you how to replace your Echo Dot's PCB which has the LEDs, Microphone, and Buttons. It shouldn't take long, just a few screws!
Выберете то, что вам нужно
Turn your Dot around, so that the Barcode is facing up, and the buttons down.
Инструмент, используемый на этом этапе:TR6 Torx Security Screwdriver$5.99
Unscrew the 4 T6 Torx screws using the Right Screwdriver
After unscrewing, you can slowly lift the shell, and you'll be greeted by the insides of the Dot!
Unscrew the 3 T6 Torx screws,
and lift the flex cable connector.
After that, very carefully remove the PCB/Power supply (no idea).
Remove the 4 T6 Torx screws (2 different lengths!)
Slowly Remove the Middle part
Simply flip the device to separate the:
Motherboard and
Buttons from each other.
Congrats! To put together your Echo Dot, simply follow the instructions backward! Have a nice day!
Еще один человек закончил это руководство.
