Введение
Use this guide to replace the throttle trigger in an Echo Power Pruner 254 cc PPT2620 2019.
Выберете то, что вам нужно
Pull the spark plug cap straight off of the spark plug.
Use a T25 Torx screwdriver to loosen (but not remove) the two screws clamping the main pipe assembly to the control handle.
Remove seven T25 screws holding together the control handle.
Pull the throttle cable sideways through the slot in the throttle trigger to remove it from the trigger.
