Введение
This guide is required when there is no audio coming from the device as a result of a broken speaker. To replace the speaker, it is required to solder the replacement speaker to the motherboard. This is a safety hazard and specific soldering equipment is needed. When soldering, protective equipment needs to be warn for caution.
Выберете то, что вам нужно
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws
Using the small metal pry bar, remove the bottom plastic cover.
Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
