Введение
This guide is used when the toggle button is no longer functioning properly. If you are experiencing a loose or broken toggle button it must be replaced to keep the device operating normally.
Выберете то, что вам нужно
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Using the small metal pry bar, remove the bottom plastic cover.
Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart
Using the screwdriver, remove the four 4.8 mm Phillips head J00 screws at each corner of the motherboard.
Remove the motherboard from the front plastic cover and screen. Replace the old motherboard with the new motherboard.
Инструмент, используемый на этом этапе:Tweezers$3.99
Use the angled tweezers to disconnect the toggle button covering.
