Введение
You will need a phillips head screw driver and needle nose pliers to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
Выберете то, что вам нужно
Remove the four screws that hold down the speaker and pry up the speaker from the frame.
Once the voice coil is removed, solder it back onto the bracket or replace the voice coil entirely.
Почти готово!
Заключение
