Введение
This guide can be used to replace the DEEBOT D35 motherboard. The Deebot D35 motherboard is responsible for controlling the vacuum's progress across floors. Special care must be taken when removing wires and the motherboard from the D35, as well as reassembly.
Выберете то, что вам нужно
Remove the 9 screws with a PH2 Phillips screwdriver on the underside of the D35. The screws are:
7 x 14mm screws
2 x 10mm screws
There are 5 cables that need to be carefully disconnected before completely disconnecting the back cover:
The 5 cables two blue cables on the front left and right side (located next to the sensor). Represented by the red arrows.
Multicolor ribbon in the front center. Represented by the blue arrow.
Two (black and red) two prong adapter connected to the motherboard. Represented by the green arrow.
Remove the screws from the motherboard with a PH2 Phillips Head Screwdriver. The screws are:
2 x 14mm screws
1 x 10mm screws
2 участников успешно повторили данное руководство.
