Ecovacs DEEBOT D35 Vacuum Motor Replacement
Выберете то, что вам нужно
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: шаг 1, изображение 1 из 1
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: шаг 2, изображение 1 из 1
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: шаг 3, изображение 1 из 1
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: шаг 4, изображение 1 из 1
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: шаг 5, изображение 1 из 1
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: шаг 6, изображение 1 из 1
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: шаг 7, изображение 1 из 1
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: шаг 8, изображение 1 из 1
    • Remove the vacuum motor body
Заключение
3 участников успешно повторили данное руководство.
Brian
Участник с: 02/15/17
475 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 12-2, Eyestone Spring 2017 Участник USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
4 членов
Автор 4 руководств
Один комментарий
thanks a lots for the valuable info
sk law - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 8,969
