Введение
Use this guide to replace the battery in your Ecovacs Deebot 900 if it is malfunctioning or will not maintain a charge. The battery allows the Deebot 900 to maintain power without being plugged into a power source. It may become necessary to replace a malfunctioning battery.
Removing the battery when repairing anything inside the robot is also recommended for safety.
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
5 участников успешно повторили данное руководство.
5 Комментариев
Great guide except no information on where to actually FIND a battery for this thing
Where can replacement battery packs be acquired from?
Amazon also sells them. Make sure to get one for the correct model though (there are alot of them)
