Введение
The front bumper of the Ecovacs Deebot 900 is used to sense obstacles in its path. A malfunctioning front bumper can cause the Deebot to move in a circular fashion. Use this guide to remove or replace the front bumper on your Ecovacs 900 Deebot.
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Disconnect the two cables connecting the bumper to the body of the Deebot.
Remove the front bumper from the device.
Еще один человек закончил это руководство.
Один комментарий
Where may I buy the front bumper assembly? I'm trying to replace one for a deebot 901 but the mfg tells me they don't see the part directly.
