Введение
The motherboard is a crucial aspect to controlling the Ecovacs Deebot 900. Unfortunately, the motherboard is easily fried if the robot accidentally vacuums water and may need to be replaced. Use this guide to replace the motherboard in the Ecovacs Deebot 900.
Выберете то, что вам нужно
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Disconnect the two cables connecting the bumper to the body of the Deebot.
Remove the front bumper from the device.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Insert a Jimmy into the seam and work all the way around the robot.
Disconnect the two cables and remove the bottom case from the device.
Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.
4 участников успешно повторили данное руководство.
2 Комментариев
Any suggestions on purchase options?
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
