Введение
The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the vacuum motor is not working, the Deebot will not pick up debris and will be unable to clean. Use this guide to replace the vacuum motor of your Ecovacs Deebot 900.
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.
Using the two white straps on the sides of the battery, gently remove the battery.
Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Disconnect the two cables connecting the bumper to the body of the Deebot.
Remove the front bumper from the device.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Insert a Jimmy into the seam and work all the way around the robot.
Disconnect the two cables and remove the bottom case from the device.
Using the Phillips #00 screwdriver, remove the three screws around the laser unit.
Remove the single screw holding the motor assembly in place using the Phillips #00 screwdriver.
5 участников успешно повторили данное руководство.
Один комментарий
Where can you find a replacement vacuum motor for the zoom 930?
