Введение
Edwin the interactive toy cannot work if the central most crucial part of Edwin, which is the motherboard, does not work. If there is water damage, and Edwin is no longer working, this guide will take you through the steps of replacing it.
Выберете то, что вам нужно
Unscrew the four 9mm screws with a T8 screwdriver bit
Remove the back plate off
Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
Using the plastic opening tool pull up the black tab up until it stops.
Pull up the white cable tab, up slowly
Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
Remove the top connector as you see in the picture.
Replace the new motherboard and you are finished.
Еще один человек закончил это руководство.
